Modifying an axle stand.
Rorschach
Has thanked: 108 times
Been thanked: 1038 times
Post by Rorschach »
I have a pair of Axle stands, not modern chintzy stuff that looks like it is made from tin foil, proper English made solid ones using thick steel, they are heavy and sturdy.
However they have an annoying little niggle when combined with my car/jack. There are 3 pin holes, spaced 2" on centre. Whenever I jack the car up, there is never a hole in the right place and I always end up having to jack the car up another 2" because the lower hole is always a fraction too low for the job at hand.
You might not think that a problem and sometimes it isn't, but I don't always work in idea conditions and sometimes I run out of travel with the jack or get close to it and I would really like a little more adjustment in the stands.
So my plan is to drill another 3 holes, bisecting the current range, giving me 1" increments. Drilling them in between the current holes would introduce weakness clearly as the pin holes are large and take a substantial sized pin, which is good. So I thought I would drill them at a right angle to he current set of holes. I don't think this would introduce any significant weakness to the tubes, they have a 3mm wall thickness which is much thicker than I have seen on modern stands. Crazy idea?
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Re: Modifying an axle stand.
Post by ayjay »
I'm no engineer so can't really comment on how drilling holes would affect the strength, (but I'd be a bit wary of doing it myself).
Why not a shaped hardwood block fixed to the top? A piece one inch thick would give you the flexibility you're looking for.
mikew1972
Has thanked: 10 times
Been thanked: 110 times
Post by mikew1972 »
I'm pretty sure it would be stronger (and less annoying) with all the holes in a straight line.
Mike
Has thanked: 823 times
Been thanked: 3558 times
I thought about this and I think I would be inclined to offset the new holes to give as much strength as possible. The logic is that the pin and surrounding metal takes what is a compressive load so I would have thought that more metal would make it stronger. Having said this I have no reason to suggest that in line holes would be a hazard but you want to be reassured if you are under a heavy vehicle on the stands.
Rorschach
Post by Rorschach »
mikew1972 wrote:I'm pretty sure it would be stronger (and less annoying) with all the holes in a straight line.
What makes you think this? Genuinely curious here. Drilling 10mm holes between the holes already there significantly reduces the material between each hole making it weaker in my mind.
Also I don't think it would be annoying having the holes on the side :dunno:
Rorschach
Post by Rorschach »
ayjay wrote:I'm no engineer so can't really comment on how drilling holes would affect the strength, (but I'd be a bit wary of doing it myself).
I did consider this as I have used wooden blocks with a jack in the past. My main issue with that though is that they tend to slide off and/or get jammed on the pinch weld which is where I most often use them.
ayjay
Post by ayjay »
Drill a couple of holes in the wooden block and the top plate and drop two bolts through the whole lot, if it's going to be permanent, put a nut on it as well.
Rorschach
Post by Rorschach »
If it's permanent then I am still stuck with 2" height increments. I want to be able to easily raise the stand in 1" increments. I would have to remove the block every other notch.
Bob225
Has thanked: 105 times
Been thanked: 878 times
Post by Bob225 »
don't do it your weakening the steel
A wooden block or some adjustable stands, yes they do make decent ones (draper 2 ton ratchet type) what are £25-30 or a set of ramps, if your doing regular work a set of quick jack lift may be a option
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Post by Dave54 »
Isn't there some rule of thumb for putting holes in stuff like that?
I vaguely remember something about so many diameters of hole between holes. (Or I think I do).
Anyway, whatever, I wouldn't be keen on drilling holes in axle stands to hold up a vehicle I would be climbing underneath.
I don't like working under vehicles on stands at the best of times
Rorschach
Post by Rorschach »
Dave54 wrote:Isn't there some rule of thumb for putting holes in stuff like that?
I don't work under the vehicle on stands anyway, or very rarely. It's only on stands for doing things like swapping wheels, or brake work etc. Anything that isn't wheel related such as an oil change or when I recently had to replace part of the exhaust and the car goes up on ramps instead.
If I were to need to go under the car without ramps then I would add blocking as well as the jack stands.
I think I'll give it a go and take extra precaution the first time I use them. If they break then I'll just get a new set of ratchet stands instead. I really don't think they will, these are old school 2 ton stands made of thick steel and are used to hold half the weight of a 1.2 ton car.
Rorschach
Post by Rorschach »
If I die, feel free to say I told you so. :lol:
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
There's loads of meat there. I wouldn't be worried about it in the slightest.
Rorschach
Post by Rorschach »
Hitch wrote:There's loads of meat there. I wouldn't be worried about it in the slightest.
That's what I thought. There 1.5" centre to centre between the new and the old holes and the pipe is 3mm wall thickness. It was nice to drill too, not gummy or anything.
mikew1972
Post by mikew1972 »
Was thinking the overall resistance of the tube to being bent or crushed. Don't know. There'd be some pretty complex maths involved to be sure. Maybe Hitch knows?
Surely it's easier to see which is the lowest hole you can put the pin through if you don't have to start twisting it back and forth to see all the holes?
Anyway it looks plenty strong the way you've done it so problem solved and all good?
Mike
Locked
