Need some input with my problem
Posted: Fri Jul 27, 2018 9:55 pm
by CELTICPSYCHO
Hi. Maybe im stupid, but cant find the problem with my pc.
Was told that the psu was shot. Bought another one, but still a no signal on the monitor, then no power. Changed over 5 vga cables earlier too. Same issue.
Can it be my on board graphics? Please
Sent from my vivo Y27 using Tapatalk
Re: Need some input with my problem
Posted: Sat Jul 28, 2018 8:29 am
by gas4you
Can you borrow another monitor to test it?
Posted: Sat Jul 28, 2018 8:42 am
by kellys_eye
Do any lights come on? Does it make any noises? Can you hear the fan running? Any beeps?
Posted: Sat Jul 28, 2018 11:02 am
by Dave54
As the others have said. Also check that there is actually mains power to the computer and monitor. Check that the switch on the back the PSU is on if there is one. Check that the monitor itself is turned on.
Posted: Sat Jul 28, 2018 1:47 pm
by Bob225
make sure the psu is switched on at the back and that the fuse in the plug isn't blown, it could be no end of issues
do the fans or hdd make a noise, what make of machine and spec is it ??
