exterior rendering and damp
Can anyone give me some advice.
I have a small bit of rendering to the front of my house and it goes down to the floor. Some of the rendering, mainly at the bottom, has come off. Having had three quotes, only the third said I needed the bottom of the rendering removing and a drip bead applying, together with bitumen coating. His quote is also three times the cheapest for all this extra work.
Can anyone tell me if this is correct? I have no damp proof course in the wall and no signs of damp inside (but this is also below the floor level of the house anyway). Or could he be trying it on? Any help would be welcome. Many thanks.
- Has thanked: 16 times
- Been thanked: 9 times
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
- Has thanked: 3 times
- Been thanked: 31 times
Hi tutti,
Those grey bricks may well be a very early type of engineering brick and the 2 courses are probably acting as you dpc, any render on or below these will be subject to damp and also acting as a bridge for damp as UHM as said there should be no render below the dpc.
Personally i would go with the builder/plasterer who quoted you for a drip bead and painting with RIW or if the bricks are sound then have them raked out and repointed as you will never be able to remove the RIW ie bitumen when it has been applied.
Hope this helps
Hope this helps
