Faulty Gearbox
QualityKitchens
Has thanked: 7 times
Been thanked: 1 time
Faulty Gearbox
Post by QualityKitchens »
I've just bought a Volkswagen Polo which is a over 10 years old. You could say I have a real need for speed! :lol:
Anyway, I've had it for a few weeks and the gear box keeps popping our of gear! It's happened a couple of times in short succession, once going from stationary onto a road, once doing about 30 and putting it into 4th, and another time when I stalled it. Is there something wrong with my gearbox or is it just a fault with the nut behind the wheel? :roll:
Has thanked: 823 times
Been thanked: 3560 times
Re: Faulty Gearbox
Probably the selector linkage not pushing it into gear fully. Search VW shifter linkage, there are loads of videos and threads on owners forums. :thumbright:
QualityKitchens
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Re: Faulty Gearbox
Post by arco_iris »
QualityKitchens wrote:just a fault with the nut behind the wheel? :roll:
The nut behind the wheel may have a screw loose. Great effort at pushing up your post count? So you can give us something we weren't looking for.
Bob225
Has thanked: 105 times
Been thanked: 878 times
Re: Faulty Gearbox
Post by Bob225 »
what year and engine ? as above its the bushes in the linkage or a bad engine mount (lower mount) I would also check the gearbox fluid level too
edit. make sure the floormat hasn't slipped up behind the clutch pedal
These users thanked the author Bob225 for the post:
QualityKitchens
QualityKitchens
Re: Faulty Gearbox
Bob225 wrote:what year and engine ? as above its the bushes in the linkage or a bad engine mount (lower mount) I would also check the gearbox fluid level too
It's not the floormat. That was the first thing I thought too!
Year is 2008. Not sure with the rest, will have a proper look under the hood tomorrow.
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Re: Faulty Gearbox
Post by aeromech3 »
:withstupid: If it is happening in more than one gear and when torque applied then highly unlikely the g.box more like engine movement and or linkage.
Bob225
Re: Faulty Gearbox
Post by Bob225 »
Iirc 2008 make it a 9n3 if its anything like the golfs it eats the bushings for breakfast (especially the cheap pattern part ones) you can get aftermarket uprated ones
not 100% but the golf and the polo share the same 5 speed on the larger engine cars
