fixing into steel ?
Posted: Sun Oct 14, 2018 6:55 am
Top tip for drilling into steel. Start with a small 1 or 2mm drill bit (which will go though fairly easy) then drill out the same hole going up 1/2mm drill bit each time. You'll breeze though the lot in no time
