Hole saw for thin metal?
Nos
Has thanked: 3 times
Been thanked: 80 times
Post by Nos »
Need to drill a 80mm hole in some thin galvanized metal, to make a smoker. Have always used "Starrett" in the past, but at £40 for something I will only use once is a bit steep. Cheap hole saws tend to be for wood and non ferrous, any alternatives or better makes, that will do the job? Thanks Nos
Has thanked: 736 times
Been thanked: 2341 times
Re: Hole saw for thin metal?
jigsaw and curved blade ba l119
https://duckduckgo.com/?q=bo+lol+jigsaw ... Tools.jpeg
assuming around 0.5-0.75 mm steel
Rorschach
Has thanked: 109 times
Been thanked: 1038 times
Post by Rorschach »
Jigsaw or drill mounted nibbler would be ideal for this size hole, assuming thickness as above.
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
Clamp it between two pieces of wood and drill through the wood.
Nos
Post by Nos »
After the fire I lost everything so at least now I can buy a new jigsaw :huray: and will use it in years to come, thanks.
OchAye
Has thanked: 855 times
Been thanked: 994 times
Post by OchAye »
kellys_eye wrote:Clamp it between two pieces of wood and drill through the wood.
Aye. Otherwise it will feel like he is holding a runaway ayebrator .... damn spell checker.
EDIT: "vi...tor".
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Buy a cheaper hole saw.
Ive used loads of cheap holesaws. Even the Titan branded ones from screwfix work fine.
Nos
Post by Nos »
Thanks Hitch I do have some hole saws some "Wolf" ones and some cheap ones, have measured the thickness and its .80 mm, I would prefer to use a hole saw as it will be a neater job, so think I will give it a go when I get some flue pipe, thanks again. Nos
Chippo1
Has thanked: 10 times
Been thanked: 194 times
Post by Chippo1 »
Tow pieces of wood work well especially if securely clamped , you get a neat hole and now distortion of the plate. Also done this at work when I snapped a mandril and dint have a spare , once you have a hole in a piece of wood with hole and clamp no need for mandril.
Hitch
Post by Hitch »
As long as its not the type where numerous ones fit onto a large back plate/mandrel at once.
Nos
Post by Nos »
Managed to cut a nice hole, had to use one of the cheapo stackable sets at about £4, I took my time with DW putting oil on all the time and stopping regularly to stop overheating, didn't think it was going to work, but it did, the saw of course now, would struggle to cut through warm butter :cb , but Iam happy :huray: now to get the pig in for smoking :scratch: :scratch: Nos
