Blown plaster
All building related posts in this forum please
mole81
Has thanked: 39 times
Been thanked: 4 times
Blown plaster
Post by mole81 »
I've had a small bit of plaster come away from the wall, I've removed all the bad to where it is sound again. It is only a tiny area, can I put some ready to use skim straight on top or would I need to pva and some kind of base first? Don't want to buy any big bags as it will be wasted! Image
Sent from my SM-G930F using Tapatalk
toolbox
Has thanked: 128 times
Been thanked: 210 times
Re: Blown plaster
Post by toolbox »
Have you discovered why it has blown is it damp?
Should be fine to plaster using a patching plaster from a DIY store, I would not worry about PVA myself.
mole81
Re: Blown plaster
Post by mole81 »
toolbox wrote:Have you discovered why it has blown is it damp?
Not sure, guess could of always been like it. Had the damp man round to check and he checked while house and none dry so shouldn't be that. So just one coat of patching plaster? Or would filler suffice?
toolbox
Re: Blown plaster
Post by toolbox »
You may well get away with filler but do several coats rather than trying to go full depth in one go, I like Toupret filler myself.
https://www.toolstation.com/shop/p22146 ... tr=Toupret
mole81
Re: Blown plaster
Post by mole81 »
toolbox wrote:You may well get away with filler but do several coats rather than trying to go full depth in one go, I like Toupret filler myself.
Thanks! Could I use ready made skim in one go?
toolbox
Re: Blown plaster
Post by toolbox »
If it says it is suitable for the thickness you have it is ideal, as long as you can get a small bag.
OchAye
Has thanked: 855 times
Been thanked: 994 times
Re: Blown plaster
Post by OchAye »
Just use filler (Toupret here too). And if in doubt, if you got a spray bottle spray the surface with some water a few minues before you fill .. to stop any absorption that may be too much for the filler.
These users thanked the author OchAye for the post:
mole81
mole81
Re: Blown plaster
Post by mole81 »
OchAye wrote:Just use filler (Toupret here too). And if in doubt, if you got a spray bottle spray the surface with some water a few minues before you fill .. to stop any absorption that may be too much for the filler.
Thanks for this, when would I need to use pva out of interest?
toolbox
Re: Blown plaster
Post by toolbox »
I tend to use it for cement skim or large areas just wetting should do for thst bit.
These users thanked the author toolbox for the post:
mole81
mole81
Re: Blown plaster
Post by mole81 »
toolbox wrote:I tend to use it for cement skim or large areas just wetting should do for thst bit.
Cheers will go with that then!
Return to “Building Forum”
