Looking for help, I am wanting to change a single socket into a double socket and want to put it flush against the wall. I was going to buy a new double backbox and replace the single backbox. The wiring that is currently going to the single backbox, can I put into the double socket or will I need to do anything with the wiring?
Single socket into double
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2572 times
Re: Single socket into double
DCOL89, go ahead, but do make sure you turn the mains off first. (No need to worry is it a spur or on a ring)
- Someone-Else
That is correct since you are only changing from single to double.
- wine~o
- Has thanked: 1414 times
- Been thanked: 4017 times
Your main issue is going to removing the old single metal back box without damaging existing wiring. Be very careful.
New back box must have grommets fitted.
- Has thanked: 26 times
- Been thanked: 174 times
What about using a single socket to double socket converter ? it fits in a single socket back box but gives you a double socket. i've installed a couple in the MILS Flat because its a council property and didnt want to starting chasing out bigger back box holes in the concrete and brick work.
https://www.screwfix.com/c/electrical-l ... /cat830536
