Advice on this work?
The job was to replace rotten beams, install a lintel above an old doorway. Prepare a wall and brickwork, ready to install a window.
Would be grateful for people's thoughts on the work. Can post more pictures on request.
- IMG_0794.JPG (126.15 KiB) Viewed 11056 times
- IMG_0793.JPG (113.58 KiB) Viewed 11058 times
- IMG_0792.JPG (106.28 KiB) Viewed 11058 times
- IMG_0790.JPG (97.1 KiB) Viewed 11058 times
- IMG_0791.JPG (95.09 KiB) Viewed 11058 times
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Re: Advice on this work?
Where joists are sistered they should be coach bolted together (ideally with *Timber Dogs*) in between them.
Usually the rotten part is removed, and then a 1200mm overlap is required on the existing timber that remains.
I'd be concerned about the white stuff on the bottom of the floorboards, (not the foam, that'll cut back and clean up OK) it could be dry rot, (which is whole new ball game).
- Has thanked: 105 times
- Been thanked: 878 times
Its not great, that's been exposed to moisture/rain - the white mould can cause all sorts of health issues if its not treated or removed properly plus you don't know how far it penetrated
expanding foam is a bodge imo, it looks like the bricks are stuck together with it
I take its a cellar or basement ?
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1573 times
As the others have said. Not a good job at all. Also where the sistered joists are installed hab=ve the notched ends been treated? And why was a piece of untreated timber (the light stuff used beneath the steel) used? In a situation such as this any fresh timbers installed should be treated and all signs of rot needs to be methodically removed. Not the best of work I have to say
- Has thanked: 201 times
- Been thanked: 510 times
I can't see any bolt heads on those sistered joists either , to be honest I'm not sure I can make out any fixings.
Edit , just noticed ayjay has mentioned the same thing.
- Job and Knock
You're right - he's nailed then from the look of it.Grendel wrote:I can't see any bolt heads on those sistered joists either , to be honest I'm not sure I can make out any fixings.
- Has thanked: 18 times
- Been thanked: 13 times
How similar can you get work wise but i think I'll leave out the foam this time
damage But i won't be taking any tips from this job
Starting Job soon on mates 1920's semi rear door with leaking bath above wants seal up door and repair damage But i won't be taking any tips from this job
