Morning all
Has anyone heard of the above ?
Have seen these advertised by a local computer repair/IT solutions company. Fairly good specs and considerably less than the equivalent HP, ACER, DELL etc
Or is it a case of , if it sounds too good to be true ...............................................
GALXION COMPUTER
- Has thanked: 29 times
- Been thanked: 4 times
- Has thanked: 855 times
- Been thanked: 994 times
Re: GALXION COMPUTER
Never heard of them, but then I will not have heard of many/most small assemblers. What matters is the quality of components inside, and if there is a clash of drivers down the road it will be down to you to sort out.
- These users thanked the author OchAye for the post:
- pistonbroke1957
- Has thanked: 98 times
- Been thanked: 872 times
Its more than likely their own brand, as above it all depends on the quality of the components
I could build a dirt cheap system using no name Chinese junk, but I wouldn't be willing to put my name on it, a year to 18 months if not sooner it will start to fail
Scan do some reasonably well spec'd systems for the money
edit. Found it bl-it in Gillingham, I5, 2tb hdd and windows 10 be aware that is based on ddr3 memory, in a low cost case and there's no knowing what psu is in it I assume its the one what comes with the case (case and psu is sub £20 Retail)
- These users thanked the author Bob225 for the post:
- pistonbroke1957
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
in 18 moths the damned thing will be obsolete.......Bob225 wrote:.... a year to 18 months if not sooner it will start to fail
- pistonbroke1957
I know of machines I built still running, getting on for 20 years old in daily use
I no longer build as I will not build machines with cheap parts, as such the margins are thin - you get, what you pay for (to a point)
I wouldn't even bother with a system that doesn't have a SSD/M.2 boot drive with a absolute minimum of 8gb ram
- pistonbroke1957
Thanks for all the replies.
Not knowing much about Tech, think i'll stick to a named brand
