I am no particular fan of Worx over any other make; but started out like so many people with a drill, and once having the batteries and charger it made sense to stay with the same brand.
Combi Drill WX384
As mentioned, this was my first cordless power tool purchase... was desperate for a new drill as my previous inherited and ancient jobbie had a brushed motor (lots of sparks and burning smells), an olde worlde keyed chuck and worst of all a power cord! It had to go but with no idea what to look for I was recommended to get a brushless one, and they're obviously pretty much all keyless and cordless these days anyway.
Chose this Worx drill on Amazon for a smidge under £100 complete with a fast charger, case and 2 x 2.0Ah batteries. It's had loads of use in the last 18 months or so. Reasonably powerful (40Nm torque), battery life is excellent (perhaps the brushless motor helps?) and reliability has been good, though the trigger occasionally sticks.
It's pretty light and compact, and overall I like it!
Tip: For masonry I use Bosch blue multi-construction drill bits; so much better than crappy cheap ones and well worth the investment in my opinion... *other quality drill bits are available
Impact driver WX292
My favourite power tool! It's brushless, super powerful and I just love the way it drives screws in so easily. It's not perfect though... it doesn't have a 2 or 3 speed gearbox like some fancier products, the speed is instead controlled via the trigger and I sometimes find it a bit difficult to modulate due to a bit of stiction in the trigger mechanism. To be fair I am guilty of sometimes using it when not strictly necessary... for some jobs it is total overkill. But as said I enjoy using it so there you go
Tip: Similar to above, I've invested in a set of impact driver specific bits. Mine are DeWalt and no breakages yet despite quite a bit of use.
Rotary Hammer Drill WX390
To be honest I've only used this once so far. We live in a Victorian house and the bricks are very variable in terms of hardness. You can drill with a combi like a red hot poker into butter, the try again 2" to the left and it just spins. This gave me a but of a mental block about drilling masonry, but since taking up handiwork as a job I reckon loads of practice, increased confidence plus (not to be underestimated) the use of decent drill bits and the SDS hasn't really been needed... yet.
The one time I tried this drill out, it whacked its way into the brickwork with ease... However, I'd advise down-sizing the drill bit used, e.g. for an 8mm hole use a 7mm bit at first, then bore it out with an 8mm bit if necessary. This was maybe down to my inexperienced SDS drilling technique, but it's obviously a lot more aggressive to use than a combi.
There is no chisel function, it's a compact SDS... think of it as a next step up when your combi drill is struggling with masonry. For core drilling or chiselling you will need to look elsewhere. However, it's very light for an SDS which would surely be beneficial if you had loads of holes to put in brickwork.
Overall, once again I like this drill but only time will tell how it fares.
That's enough typing for now, but look out for the next thrilling instalment in which I will enthral you with tales of my circular saw, jigsaw and multi-tool... bet you can't wait!
