Builder from Hell
- Has thanked: 4 times
Builder from Hell
I am in the process of trying to put right all the cockups this builder has done. We only discovered this when we removed a pile of rubble.
The picture shows what a moron the builder was as there was a pile of rubble next to the new build and he rendered the outside down to the rubble.
More worrying he seems to have built this on lintels which I am not sure about.
As this was replacing an existing extension the builder told me I don't need building regs and was totally against me contacting the council
Now I am frightened to in case they want me to knock it down ? I know I should have ignored the builder but feel I still should contact the council
Any advice on the footings would be a great help. He did put concrete in a trench and then for some reason built some small pillars to put the lintels on There were several drains and pipes but surely the lintels should have something under them ?
I just want to do bad things to this so called builder !!
- IMG_20190406_121831377 (4).jpg (431.15 KiB) Viewed 7631 times
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Re: Builder from Hell
Your post is very confusing and difficult to understand, (the picture doesn't really help much either).MichaelJames wrote:
Are the lintels spanning over the "drains and pipes"?
Hi There are footings about 18inches deep then he has built small piers over the drains and pipes and bridged these with Lintels
However there seems to be more lintels than there were pipes and drains and the lintels are only supported at each end on the small brick pillars.
Should the Lintels not be supported in the middle with cement or would this stop the lintels from doing there job in protecting the pipes and drains.
Is it ok to support the wall on these lintels ? (Which by the is block work not bricks )
I just don't trust this builder now or anything he has done.
Many Thanks
PS I had to crop the original photo as it was too wide to upload
Many Thanks
- Has thanked: 98 times
- Been thanked: 872 times
we have 2 lintels under our extension due to drainage
The only way to tell is dig out a trench, hopefully you never let the builder sort out the building control, and building control passed the footings/foundations
That render looks shocking
edit. I will see if I have a pic of ours
Here you go.
Here you go.
- These users thanked the author Bob225 for the post:
- MichaelJames
- wine~o
- Has thanked: 1414 times
- Been thanked: 4015 times
You have no real option other than to get building control out. If they condemn the work done so far then you'll prolly have to take the builder to court, maybe small claims court depending on how much you've already paid.
- These users thanked the author wine~o for the post:
- MichaelJames
- Has thanked: 107 times
- Been thanked: 1038 times
Get building control out, if condemned get a report from them or an independent surveyor. Start court proceedings.
