i have just got new light switch's for hall and up stairs
i did not take note of the wiring on the double switch at the bottom of the stairs and have wired it wrong because when the double switch is on the other switch's wont work but when off they do here is how all the switches are wired
the 1st light switch in hall it is wired like this
com = blue
L1 = yellow
L2 = red
[b]the 2nd is a double
com = blue
L1 = yellow
L2 = red all from the same wire
com = blue
L1 = yellow
L2 = red all from 2nd wire
[/b]
[/b]
and up stairs i have
com = blue
L1 = yellow
L2 = black
light switch help
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
- sparkydude
- Has thanked: 2 times
- Been thanked: 149 times
at the top off my stairs i have a single switch (1g) what controls one light
that light is at the top of the stairs
the wires i have are
blue
yellow
black
and 2 red that are connected to each other witch Block Connector
and the switch i have for that has
C
L1
L2
the other single switch(1g) i have is at the end of hall what controls two lights one light in the hall the other at bottom of stairs
blue
yellow
red
C
L1
L2
the i have a double switch (2g) one of the switches on the (2g) controls the same as the one underline above
and the other switch on this controls the same as the one in bold at top of page
and the wires i have are
blue
yellow
red all from the same cable
and the 2nd cable is
blue
yellow
and the switch i have has
2 C terminals
2 L1 terminals
2 L2 terminals
but i dont know where any of the wires go help please
i can get the switches working on there own but not all together
hope this makes sence
blue
yellow
black
C
L1
L2
blue
yellow
red
C
L1
L2
blue
yellow
blue
yellow
2 C terminals
2 L1 terminals
2 L2 terminals
- sparkydude
[quote="zippo84"]at the top off my stairs i have a single switch (1g) what controls one light
blue =L2
yellow =L1
black=common, put some red tape over this
LEAVE THE 2 REDS AS THEY ARE
C
L1
L2
blue =L2
yellow=L1
red= Common
C
L1
L2
blue
yellow
blue
yellow
2 C terminals
2 L1 terminals
2 L2 terminals
Simply follow my colour code on this switch, keep each cable to 1 switch , yellow=L1 Blue =L2 Red = Common
Try these combinations and i think you should have them working in no time, any problems get back to me. Oh yes, the yellow and the blues should be sleeved with red sleeving, or red tape to indicate they are live conductors.
Nick
blue =L2
yellow =L1
C
L1
L2
blue =L2
yellow=L1
red= Common
C
L1
L2
blue
yellow
blue
yellow
2 C terminals
2 L1 terminals
2 L2 terminals
Nick
