Perspex sheet to tiles
- Has thanked: 21 times
- Been thanked: 5 times
Hi guys I’m putting a Perspex sheet over wall tiles and wondered if anyone could recommend a non solvent adhesive to use as I know on most adhesives it says one of the surfaces must be porous?? Please help
- Has thanked: 107 times
- Been thanked: 1038 times
- Has thanked: 285 times
- Been thanked: 402 times
Re: Perspex sheet to tiles
We had to do the same in a rental property and the adhesive was supplied as part of the deal and it was similar to this https://www.toolstation.com/soudal-fix- ... 0ml/p84704
It is quite thick to squeeze out so you will need a decent caulking gun like this https://www.toolstation.com/cox-powerfl ... gun/p66651
And don’t be mean with the adhesive!!
And for what it’s worth , 2 tips
1. Measure twice ( at least ) and cut once
2. Offer the panels up for a dry fit before applying adhesive
Mike
Mike
This is their spec and it does seem to fit what you want
http://www.soudal.com/soudalweb/product ... 82&ID=1907
Mike
Mike
- bgatty68
- wine~o
- Has thanked: 1414 times
- Been thanked: 4015 times
What colour (if any) is the perspex ?
- wine~o
Coz if it had been clear or translucent then the sealants linked to above would have shown through.bgatty68 wrote:Wine o it’s black why
I try to be thorough
- wine~o
Should be, personally I'd use CT1 or Geocel the works (Both available in clear) but those are just my prefered adhesives.bgatty68 wrote:Wine o so you think it should be ok?
Are they non solvent though?wine~o wrote:Should be, personally I'd use CT1 or Geocel the works (Both available in clear) but those are just my prefered adhesives.bgatty68 wrote:Wine o so you think it should be ok?
If you have concerns about the adhesive showing through ( it shouldn’t ) then use something like this
https://www.toolstation.com/sticks-like-290ml/p98810
And the data sheet
https://www.dvakim.com/wp-content/uploa ... ZE0449.pdf
Mike
And the data sheet
Mike
I really would just recommend a bog standard silicone for this. It sticks well to tiles and perspex but could be removed if you needed to in the future without damage.
