Lidl 26th May
The Bargain Tool forum. This is for regular members to post about bargain tools. It is not for spammers to post links to tool sites!
boxedin
Has thanked: 61 times
Been thanked: 319 times
Lidl 26th May
Post by boxedin »
Range of 12v cordless tools with 2AH, £9 and 4Ah £15 battery options
Jigsaw £25
Karcher K2 £60
Japanese saw £6
Zip off keks with knee pads £10
Drill bits, jigsaw blades, etc
Magnetic tool assortment
https://www.lidl.co.uk/en/MiddleofLidl. ... 074&week=2
These users thanked the author boxedin for the post (total 3):
ArgyllOchAyeAPDIY
Rating: 21.43%
sammy.se
Has thanked: 90 times
Been thanked: 80 times
Re: Lidl 26th May
Post by sammy.se »
Nice one, thanks!!
Sent from my SM-G973F using Tapatalk
Has thanked: 734 times
Been thanked: 2335 times
Re: Lidl 26th May
i have several off the bosch versions angle grinder 'jigsaw' oscilating tool'drill
if the lidl perform 80% as well but at the very low 1/4-1/3 off the cost they will be very use full tools at a good price
Rorschach
Has thanked: 108 times
Been thanked: 1038 times
Re: Lidl 26th May
Post by Rorschach »
I have a drill with that battery I bought years ago, it has held up well in my secondary tool bag.
boxedin
Re: Lidl 26th May
Post by boxedin »
The trousers have kneepad pockets not knee pads.
I already have the version thats not zip off which I got for £10 they are lightweight but if you buy them roomy enough I find that they don't inhibit your movement as much as the heavier worktrousers. Get through a couple of pairs a year. Have had the zip off variant but I didn't zip them off as I use them on the allotment and its your lower legs that get scratched, bitten or hit with stuff from the mower/strimmer. Usually I put scissors in the pocket and they punch through the seam
Will give the jap saw, magnetic stuff, screw extractors, right angle attachment a go. Quite like the look of the jigsaw
Didn't get on with the 3m tape for outdoors so went back to gorilla
ahfix
Been thanked: 184 times
Re: Lidl 26th May
Post by ahfix »
I have absolutely no need for it but I quite like that 12v SDS :-)
Argyll
Has thanked: 1180 times
Been thanked: 576 times
Re: Lidl 26th May
Post by Argyll »
I fancy the Japanese saws.
tombarry
Has thanked: 18 times
Been thanked: 13 times
Re: Lidl 26th May
Post by tombarry »
Quite tempting don't know how they do it so cheap
Got my eye on the small planner as the Bosch version is around £240
recently I used their 20v cordless SDS (£40) on a job for 2 weeks, it was very lightweight to use all day
got a little warm and grease came out the rubber\Chuck but after a few days use this settled down
although they've got a long warranty You've got to expect they might not last being used in a pro. situation :-)
Argyll
Re: Lidl 26th May
Post by Argyll »
The 12v puts me off the planer. I reckon it would be underpowered and not last a couple of hours.
I bought two of the Jap saws. They look ok.
Re: Lidl 26th May
i would suspect you would be lucky to get a door or around 15-20 mins out off a 2ah battery[10.6x2x60=1272 w]
so if it uses say200w it will last about 5or6 mins continuous use
Return to “Bargain Tools”
