Hosepipes
- Has thanked: 35 times
Hosepipes
I have an outside tap and bought myself a bog standard hosepipe like my neighbours.I used the connectors supplied but water leaks or spurts out of the top.My neighbour tried a few times to fit it and put waterproof tape round it etc but it still leaks. I had a look today at other connectors and saw one which said threaded. Is this better? Not sure what it meant.
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2559 times
Hosepipes
Maybe you should post a picture of what your outside tap looks like?
Threaded means just what it says, the part in question has a thread.
- SheilaM (Sat Jul 13, 2019 9:21 pm)
- Has thanked: 98 times
- Been thanked: 872 times
Hosepipes
Buy some decent fittings either brass or Hozelock ones,
most outside taps (bibcock) are threaded either 1/2" or 3/4" and come with a spigot that screws on to the outlet
eg.https://www.ebay.co.uk/itm/Universal-Br ... hFLWRtQ-4g
Hosepipes
The one I was looking at was Hozelock. Been out to my tap,my neighbour had put the old one back on with the unsuccessful tape. I couldn't get it off so will see if someone can sort it for me tomorrow.
Hosepipes
Been there, and done that - and learnt my lesson
The cheap hose fittings rarely seal properly, within a few months the weather gets to them - if your unlucky they let go when your using the hose and get a soaking
