A simple 10 minute job...
Grumpy people only in here please
wine~o
Has thanked: 1414 times
Been thanked: 4017 times
Post by wine~o »
Sorta follows on from Someone-else's thread about getting ripped off by garages... Anyrode, my car went in for it's annual service/MOT with an independent mechanic that is really good.
Major service ( new cambelt, brake fluid needs changing, a couple of brake pipes corroded, gearbox oil needs changing, A/C needs recharging and lots of other stuff...)
I also asked him to check the battery as it's been a bit sluggish on turnover, turned out to be slightly dodgy.
So I thought I'd save a few £££'s by fitting a battery myself (His price fitted £ 85. I can get an equivalent for £ 55) Coz I'm not loaded...
Anyway ordered a battery from here https://advancedbatterysupplies.co.uk/ who I can recommend, second time I've used them. Sure enough the battery turned up at 3PM , so at 3.30 yesterday I started to replace the battery, a simple 10 minute job ::b ::b ::b
Sooo first remove the bracket that holds the battery to the tray, awkward to get at but with a socket set and 2 x 100 mm extenders could reach it, removed, sorted.
Disconnected battery connections, remove old battery, all going well.
Slide new battery in, go to replace the bracket... drop the bolt that holds the bracket down. Remove battery, look for bolt. Spot it. Wee bit tight to get my hand in between the battery tray /engine block / air filter housing. Manage to grab it out and try again.
Drop it again...
This time I can hear it rattle all the way down to the undertray, *unclips undertray and inserts hand to find bolt*
Hand now covered in all sorts of crap oil and god knows... ::b ::b ::b ::b ::b
Starts again. Just as I think I'm getting there the "socket" drops off the extension... and disappears god knows where, can't see it and not in the under tray.
Remove battery tray and wiring clipped to battery tray, can now see socket but can't reach it.
Remove air filter housing... find where the missing socket is. Retrieve ...
Re-assemble air filter housing, battery tray. Attempt to replace battery.
:angryfire: :angryfire: :angryfire: :angryfire: :angryfire: :angryfire: :angryfire:
Drop bolt that holds the mounting plate AGAIN :cussing: :cussing: :cussing: (well it is inaccessible)
Remove battery tray and associated wiring, swear a lot. Find and remove said bolt and summat else that shouldn't have been there.
Anyway that 10 minute job (replacing a Battery) took 1 hour and 40 minutes,
I think I'll leave it to my mechanic next time :roll: :roll: :roll:
Bob225
Has thanked: 99 times
Been thanked: 875 times
Post by Bob225 »
Murphys law, I did a vanos valve on 07 Mini, Dropped the M5 bolt removing it, but managed to find it, changed the valve And dropped the bolt twice more the last time it dropped down the back of a cast bracket never to be seen again 20 min trip to get a M5x16 bolt
But the outcome was a happy owner, a card with a bonus in it, turns out 3 shops and £450 later didn't diagnosed it as a £30 part and a blown fuse (one of them being a mini 'specialist', The car was going to be scrapped otherwise
ps. the Mini has a super tight engine bay especially with the 16 valve
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
Get a grip wine~o! :wink:
Have you had any problems with your Carpal Tunnels? Lack of a grip is a symptom, although it's usually quite advanced at that stage and you should have noticed other symptoms prior to that.
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Post by Dave54 »
Been there. "Just a five minute job" :lol:
One thing I have got, that makes things a bit easier when you drop stuff is one of those Lidl bendy inspection cameras. Bought for something else a while back, it's been endlessly useful for all sorts.
Last time I did something to the car, I dropped a bolt, and sure enough it rattled down to the pan. Couldn't see it. Couple of minutes with the camera with the pick up magnet attached retrieved it.
Anyway my battery's getting a touch low after a few days. 12.4 V IIRC. Starts alright, but I noticed last year that it was just a tad sluggish when it was really cold.
I'll take it in I think!
Rorschach
Has thanked: 108 times
Been thanked: 1038 times
Post by Rorschach »
Cheap battery, replace often is my motto.
In my car replacing the battery really is a simple affair (as long as I don't drop anything! lol) in my mothers car it takes much longer and requires remove several bits of engine cover, bloody thing.
Has thanked: 814 times
Been thanked: 3508 times
In the difficult bolt situation I stick the bolt onto the socket with masking tape not too thick that it will not break out once it is turning.
Bob225
Post by Bob225 »
dewaltdisney wrote: Fri Jul 26, 2019 7:23 pm In the difficult bolt situation I stick the bolt onto the socket with masking tape not too thick that it will not break out once it is turning.
The only way to get at is with a shallow socket and a 2" extension bar, its a pig of a job the rear valve it even worse - but that's French engines for ya.
Return to “The Grumpy corner”
