Intergas eco rf36 hive thermostat wiring
Frankieholmes
Post by Frankieholmes »
Can anyone help with a wiring diagram to connect a hive active thermostat to an Intergas eco rf36 boiler?
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
Bertiebasset
Post by Bertiebasset »
Hi, I can understand the wiring diagram, but 1&3 goes to low voltage side. The manual says no 240v to go to low voltage side ?
Razor
Post by Razor »
Terminals 1&3 on a Hive don't have any voltage they are just a switch, (relay).
It just takes the low voltage switch line from the boiler then send it back to the boiler when heat is called for.
If you aren't sure then why not get boiler serviced and the thermostat fitted at the same time?
Lastly the Hive is one of the least efficient thermostats you can fit to an Intergas. Anything that's Opentherm would be a much much better choice!
These users thanked the author Razor for the post:
aeromech3 (Mon Jan 02, 2023 1:29 pm)
