Tiling over a wooden floor and self leveling advice (with pics)
borr22
Post by borr22 »
Hey everyone!
Im tiling my kitchen and lounge, the lounge is 5m x 5m and is a wooden floor with a RSJ support in the middle and the kitchen is 3.8m x 2.7m but is a concrete floor. (Pictures below)
The joists in the lounge have been reinforced by sistering the joists and installing noggins.
The kitchen is 25mm higher than the lounge with 22mm P5 T&G particleboard installed.
I want to tile the whole lounge and kitchen with 600mm x 600mm porcelain tiles.
The water-resitant particle board hasnt been installed yet, it has just been laid down for the plasterer so it can be changed if needed.
My plan was to:
Install the particle board
Use a cement board backer board on top
Use self leveling compound with a wire mesh to bring the lounge to the height of the kitchen
Install a ditra membrane for both the kitchen and lounge.
Use a flexible tile adhesive
Then tile
lounge 1.jpg (157.65 KiB) Viewed 1385 times
Return to “Tiling Forum”
