How strong is steel reinforced epoxy (cold or chemical weld)?
Posted: Thu Jan 30, 2020 10:42 am
by Lance_dBoyle
I need to weld a nut to a stainless steel tube but I do not have a welder. I do have something called J-B Weld steel reinforced epoxy which I believe is also known as cold welding or chemical welding. I plan to have a threaded rod go through the tube and screw into the nut, and the rod, tube and nut will be subject to a lot of vibration. I wonder about the strength and durability of using epoxy. The product says it can withstand 5020 psi. Does anyone have experience with chemical welding? How does the bond compare to conventional welding? Do you have any recommendations or another way to securely afix a nut to a tube? Thanks
Posted: Thu Jan 30, 2020 11:32 am
by dewaltdisney
I used it to repair a cast aluminum Pressure Relief Valve on my vintage tractor. It was a pinhole that developed and oil squirted out. The repair was fine
I do not know how it will work for you but it must be really clean to get a good bond. I used carburetor cleaner spray.
I think it is worth a try for six quid.
Posted: Thu Jan 30, 2020 5:07 pm
by Bob225
Get it tig welded or use a rivnut imho
Posted: Thu Jan 30, 2020 8:02 pm
by Rorschach
Use the glue and then drill and cross pin it.
Posted: Thu Jan 30, 2020 8:57 pm
by jaeger
Without a welder I'd also use a rivnut, for a one-off you don't even need the tool, it can be done without.
https://www.youtube.com/watch?v=I6H6wr7fJYo
Posted: Fri Jan 31, 2020 8:46 am
by Argyll
You learn something every day. I didn't know what a rivnut was.
Posted: Fri Jan 31, 2020 9:04 am
by jaeger
Rivnuts are very useful, you can also get them in stainless steel ( a bit harder to install) if OP wants to keep all the materials the same.
UHM Also has his own video (I forgot about this)
https://www.youtube.com/watch?v=f7yIqKnLGPc
Posted: Fri Jan 31, 2020 4:50 pm
by Bob225
If rivnuts are new, Cleco's will blow your mind http://clecofasteners.info/
Posted: Fri Feb 07, 2020 3:22 pm
by Hitch
FLow drilling and tapping is a handy process for manufcturing...
https://www.youtube.com/watch?v=7YSVClLMp60
Posted: Fri Feb 07, 2020 6:51 pm
by jaeger
Bob225 wrote: Fri Jan 31, 2020 4:50 pm If rivnuts are new, Cleco's will blow your mind http://clecofasteners.info/
I first saw Cleco being used on 'A plane is born' I used to enjoy that series of 'A XXX is born'
Posted: Sat Feb 08, 2020 11:20 am
by Bob225
jaeger wrote: Fri Feb 07, 2020 6:51 pm I used to enjoy that series of 'A XXX is born'
Wasn't that a Louis Theroux documentary :lol:
The cleco clamps are very good too
Posted: Sat Feb 08, 2020 11:49 am
by jaeger
Last year at a car boot, I saw a box full of them but no insert tool, should have bought them but I just passed them by :cb
