Damp and mould in utility room
Maniman
Been thanked: 1 time
Post by Maniman »
Hi everyone I moved into my new home six months ago during the summer. I now have a problem with mould and damp in my utility room in the winter months. I have been advised to batten the internal wall with 25mm insulation and plasterboard the insulation. And skim plasterboard after
So I'm thinking shall I go with 2x1 batten, I'm to sure which insulation I should go for board or Thermal Foil Insulation. Could someone please advise me also my utility room is single brick I will post a picture at point.
Maniman
Post by Maniman »
Here are some pictures.
Gadget
Jack Of All Trades
Has thanked: 345 times
Been thanked: 343 times
Post by Gadget »
Maniman wrote: Mon Feb 10, 2020 4:35 pm Here are some pictures.
If you say so.. :scratch:
By eck! ©
yartin
Has thanked: 145 times
Been thanked: 129 times
Post by yartin »
Maniman wrote: Mon Feb 10, 2020 4:33 pm Hi everyone I moved into my new home six months ago during the summer. I now have a problem with mould and damp in my utility room in the winter months. I have been advised to batten the internal wall with 25mm insulation and plasterboard the insulation. And skim plasterboard after
It a waste of money IMO to create cavity. I had similar problem and considered this solution, but then drilled ventilation holes every 2.0m put covers, sanded down old paint from walls and ceiling, painted with bathroom anti mould paint, have a radiator and open window whenever possible.
Maniman
Post by Maniman »
I can see your point but I have no way of placing a radiator in this room.
Maniman
Post by Maniman »
Maniman
Post by Maniman »
Rorschach
Has thanked: 117 times
Been thanked: 1043 times
Post by Rorschach »
If you have no way of heating it then insulation is essentially pointless.
Maniman
Post by Maniman »
What are my options I'm not sure where to go from here?
yartin
Post by yartin »
VENTILATION is the keyword. Wall vents and windows.
You can always install electric wall heater, cheap to buy and run and easy to install, low energy 1KW will do the job if room is less than 10 square meters, or 2KW for bigger room.
Use anti mould paint for walls and ceilings but sand down old paint before painting.
Rorschach
Post by Rorschach »
yartin wrote: Tue Feb 11, 2020 8:59 pm VENTILATION is the keyword. Wall vents and windows.
You can't do ventilation and heating though, that's a waste of money.
Anti mould paint is a good idea though, it really does work wonders for about 5 years or so.
Maniman
Post by Maniman »
I have a 200 watt tubular heater which I will use I will also install a air brick vent. Thanks
Rorschach
Post by Rorschach »
200watts won't do anything and the air vent will lose more than 200watts easily.
yartin
Post by yartin »
Rorschach wrote: Tue Feb 11, 2020 9:25 pm
You need vents and heating. Vents to circulate air and heat to absorb humidity.
How do you dry a washing? A dryer which consists of heat and air flow. The same applies for hair dryer. A defroster is a fan heater...etc.
Maniman
Post by Maniman »
Ok thanks everyone I will install a vent and buy a oil filled heater.
