How to renovate rusty railings
Here we are going to remove and renovate these extremely rusty railings.
This is the before picture.
This is the after picture.
To see how to clean the wall please see here-
Removing rust from stone
If your wall contains moss you might want to check here- Moss removal.
Here you can see just how bad the rust is on the railings.
Firstly we have removed the railings and have moved them into the garage as it is almost impossible to renovate them in position.
To remove the rust from these railings is going to take lots of time and patience. Safety equipment is a must for jobs like this as there will be metal flakes flying all over the place during rust removal.
The rust needs to be removed and most of the paint down to the bare metal. If the rust is not fully removed it may eventually resurface at a later date.
Here we used a small 4 1/2 inch angle grinder and a variety of different attachments. A wire cup brush was used as well and a flexible sanding disk and abrasive paper to remove the rust. This was not easy and took a day or two.
This is part of the railings with most of the paint and rust removed. The railings have now been treated with owatrol oil which will prevent the rust from reoccurring.
