This bosch pmf 10,8Li multi tool relies on a sleeve or coupling to transmit power from the motor to the drive shaft of the machine. This sleeve costs about £1 and will prevent your machine from working if it fails.
- Powertool Repair videos
- Bosch pmf10.8Li, multitool repair
How to repair a hole in a copper pipe using a click fix patch repair
by admin 2,600 Views -
Bosch PMF 10.8 Li
by admin 2,377 Views -
Bosch multi construction drill bit
by admin 2,766 Views -
Bosch GOP 250 CE review
by admin 1,566 Views -
grout removal using the Bosch PMF 180E
by admin 2,570 Views -
How to repair Tarmac
by admin 2,662 Views -
Bosch PMF 180E review
by admin 3,292 Views -
How to change the switch position on the Bosch GWS 9-115 angle grinder
by admin 1,096 Views -
Bosch Professional GWS 9-115 P Grinder | PROtection
by admin 1,068 Views -
by admin 38.2k Views -
by admin 30.3k Views -
by admin 6,462 Views -
by admin 8,185 Views -
by admin 5,477 Views -
by admin 9,351 Views -
by admin 5,090 Views -
by admin 5,938 Views
