Corefix fixings | Fixing to dot and dab walls
Corefix fixings are a great way to fix to dot and dab walls. If you are not familiar with a dot and dabbed wall, it is when plasterboard is fixed to a solid brick or block wall using dry wall adhesive, or fixing foam. These walls can be difficult to fix to, without distorting the plasterboard, but the corefix fixing does it perfectly. In this video I demonstrate how to use the corefix 100 for fixing items that are up to 10mm thick and also the corefix 120 for fixing items that are up to 30mm thick.
corefix
