Glass can easily be drilled using a spear point glass drill bit, these bits will also drill ceramic tiles! For larger holes you can use a diamond coated holesaw. Whichever drill bit you use to drill the glass you will need some coolant/lubricant, Parrafin, turpentine, WD40 work well, even water can be used if you have nothing else available.
- General DIY videos
- drill glass
How to drill a hole in a glass bottle
by admin 1,234 Views -
Drill bits for drilling metal
by admin 3,052 Views -
Rustoleum Frosted glass
by admin 1,815 Views -
Pack drilling several identical items
by admin 2,393 Views -
Drilling hardened steel with ARTU drill bits
by admin 2,593 Views -
Drilling through cavity walls
by admin 4,689 Views -
Drilling metal
by admin 2,947 Views -
How to make a chain anchor point
by admin 2,645 Views -
Glass cutting using a glass cutter
by admin 2,065 Views -
Tips when drilling into a wall
by admin 3,609 Views -
by admin 39.1k Views -
by admin 30.9k Views -
by admin 19.5k Views -
by admin 6,536 Views -
by admin 10.8k Views -
by admin 8,255 Views -
by admin 8,382 Views -
by admin 5,633 Views -
by admin 9,489 Views -
by admin 5,178 Views
