In this video I drill out a broken tap using a JCB diamondtech holesaw. Drilling out a broken tap or drilling out a broken screw extractor is often very difficult and most people would get the broken tap or broken screw extractor spark eroded. There are not many drill bits that will drill HSS taps or screw extractors as they are harder than most drill bits, but the JCB Diamondtech holesaws slowly remove the hard steel. The Diamond Tech holesaw cost £17.50 from Toolstation (I’m not on commission) https://www.toolstation.com/shop/Power+Tool+Accessories/d80/Holesaws/sd1530/JCB+Industrial+Diamond+Tech+Tile+Holesaw/p16542
Some more videos that might be of interest are-
How to remove a broken bolt which is deep in a hole - https://www.youtube.com/watch?v=dJfkCj3FWBs
How to make the bolt drill guide can be seen here- https://www.youtube.com/watch?v=6mZj0J6CNYA
How to remove a rounded Allen head bolt- https://www.youtube.com/watch?v=WDOWPekMX44
How to remove a stripped screw- https://www.youtube.com/watch?v=_mTFQbaT3Zc
How to remove a broken bolt- https://www.youtube.com/watch?v=_R1b8niX13w
How to remove a rounded nut or bolt- https://www.youtube.com/watch?v=R5d0Bgvjmlk
Screw extractors | Easyouts - https://www.youtube.com/watch?v=SMrDYJvY0Ts
Removing a broken bolt using a welder- https://www.youtube.com/watch?v=aRrz-cphBY4
Remove a broken bolt using a left handed drill bit- https://www.youtube.com/watch?v=FYvaPbX1sT4
- Metalworking videos
- drill out a broken tap
