How to fit an expansion vessel
This video shows how to fit an external expansion vessel to a central heating system. If the built in expansion vessel is faulty in the boiler you need to get a registered gas engineer to replace it, but instead you can fit an external one yourself as you only need to tee into the central heating return pipe work
Central Heating videos
fit expansion vessel, replace expansion vessel, expansion vessel fitting
