How to fix a leaking gutter
Gutters can eventually leak, perhaps because the joint has separated slightly, in this video we clean the gutter out and then apply plumbers gold which is a sealant that can be used in wet conditions. This seals the joint in the gutter and stops the leak.
fix gutter, fix leaking gutter
