In this video I repair a leaking radiator valve nut by wrapping some PTFE tape around the olive. It is quite common for radiator valves to leak via the nut/olive or pipe, especially on small bore pipes such as microbore.
- Central Heating videos Plumbing Videos
- leaking radiator valve
How to paint a metal radiator
by admin 3,366 Views -
by admin 8,185 Views -
How to replace the washer/diaphragm in a toilet fill valve | Torbeck fill valve
by admin 56 Views -
How to fix a leaking gutter
by admin 4,038 Views -
How to install a towel radiator
by admin 4,277 Views -
How to bleed a towel radiator
by admin 3,434 Views -
How to bleed a radiator
by admin 12k Views -
How to install an isolation valve
by admin 2,532 Views -
How to tighten radiator valves
by admin 5,400 Views -
Never trust a single isolation valve
by admin 4,372 Views -
by admin 38.2k Views -
by admin 30.3k Views -
by admin 6,462 Views -
by admin 5,477 Views -
by admin 9,351 Views -
by admin 5,090 Views -
by admin 5,938 Views
