Wood screws can often stop gripping if the hole for the screw is too wide, luckily this is very easy to fix using some small pieces of timber, you can even use a piece of a wall plug if you have nothing else available. This video shows how to fix a loose wood screw hole easily and quickly.
- General DIY videos
How to remove a snapped screw from wood
by admin 1,225 Views -
How to use a screw digger
by admin 3,233 Views -
Wood super glue
by admin 2,378 Views -
How to cut a socket screw or machine screw
by admin 3,109 Views -
JML screw extractor review
by admin 2,155 Views -
How to use a screw extractor/easyout
by admin 3,327 Views -
Angle grinder to shape wood
by admin 3,691 Views -
How to fix a loose paving step
by admin 2,343 Views -
How to make a wood garden gate
by admin 3,886 Views -
Lubricate wood screws
by admin 3,398 Views -
by admin 37.7k Views -
by admin 29.9k Views -
by admin 19.3k Views -
by admin 6,410 Views -
by admin 8,137 Views -
by admin 9,242 Views -
by admin 5,048 Views -
by admin 5,896 Views -
by admin 5,336 Views
