How to fix a tv to a hollow wall | Nightmare job!
In this video a TV is fixed to a hollow wall, unfortunately the partition was of strange construction and was on the thin side, not only that, but the studs are 900mm apart, making this job very difficult. Fitting a TV to a plasterboard wall is normally much easier than this, but this job was a nightmare from start to finish. Firstly, the TV bracket would not fit, which meant I had to make adapter plates, then the partition was much thinner than a normal partition, with much thinner studs and they were also spaced at 900mm apart!
tv plasterboard wall
