how to fix squeaky/squeaking/creaking floors/floorboards
how to fix repair squeaky squeaking creaking floors/floorboards. Squeaking floorboards or creaking floorboards are often caused by the boards being loose, the movement that is caused when walking on the boards creates the squeaking or creaking noise. Apparently talcum powder can be used to stop the squeaking but it is unlikely that this will be a permanent fix. In this video the floorboards are fixed using Floor tite screws, which are especially made for this purpose. Fixing squeaking floorboards will mean that you have to lift the carpet in order to access the wooden floor beneath, it does not matter if your floorboards are made from solid wood or chipboard as this method will work on either type of floor.
You can get floor tite screws here - http://fave.co/2kA3xFB
squeaking floors
