How to hang a TV on a solid wall | fix Tv to wall
In this video I fix a large TV to a solid wall, this video uses properties in the UK, in different parts of the world wall construction might be different but most techniques will be similar. When fixing a TV to a wall it is essential that the bracket is fixed correctly, as any TV falling from the wall will surely be severely damaged.
Here are some videos that might help-
When fixing to a dot and dab wall you can use either of these two fixings-
Rigifix- https://www.youtube.com/watch?v=xaYfs3lr1jI
Corefix- https://www.youtube.com/watch?v=7xLhIPoO5gQ
If your wall is Thermolite or aerated concrete - Dewalt Gasbeton https://www.youtube.com/watch?v=YwAMQcbJS0U
How to use a core drill (this is useful for hiding cables in a disused chimney) https://www.youtube.com/watch?v=P0Pj9zzPN0s
SDS drills- https://www.youtube.com/watch?v=dfvSdRcSzK4
If your wall is a stud partition, this might help-
https://www.youtube.com/watch?v=awuqDum0ay8&t
hang TV on wall
