How to install a dimmer switch
This video shows how to replace a standard light switch with a dimmer switch. Dimmer switches are popular because the light in the room can be dimmed to make the room lighting less bright. Before installing a dimmer switch you have to be certain that the lamps are of a dimmable type, some energy saving lamps, LED’s and fluorescent lamps are often not dimmable so you need to check this first.
Electrical Videos
install dimmer switch, dimmer switch
