How to isolate water using a switch | Surestop
In this video I install a surestop, which is a stop cock that can be operated remotely using a special switch. The Surestop does not require electricity or batteries as it simply operates using the water pressure. I’m not sure if the surestop stop tap is reliable, so if you have used one please post in the comments section.
If you need to install cross bonding, the video is here- https://www.youtube.com/watch?v=xcSUEJZ56H0
syrestop, water switch
