How to remove moss from a roof
Removing moss from a roof can seem like a difficult task, some people reach for the pressure washer but often you can clean the roof simply using a stiff brush. Once the moss is removed from the roof the tiles are then brushed again before the roof is sprayed using a solution of moss killer, which will kill existing and prevent new moss from growing on the roof. Please be careful when working at heights as a fall could kill or seriously injure you!
remove moss from roof, roof moss removal
