Stripped threads in aluminium components or steel components can be common and in many cases, you might not know how to fix the problem. This video shows three different ways of fixing a stripped bolt hole in aluminium and steel. The first technique is to drill the hole out and tap it to the next tapping size up, then there are Heli-coil type inserts and finally Wurth Time-serts.
- Metalworking videos
- Repair stripped threads
Threads in sheet metal | Rivet nuts
by admin 2,131 Views -
How to repair Tarmac
by admin 2,661 Views -
How to cut a bolt without damaging the threads
by admin 6,938 Views -
Stainless steel cutting chop saw blade | Rage 2 stainless steel blade
by admin 1,341 Views -
Tapping threads using a cordless drill
by admin 3,013 Views -
How to repair a hole in a copper pipe using a click fix patch repair
by admin 2,599 Views -
Bosch PMF 10.8Li repair
by admin 4,671 Views -
How to repair a completely stripped backbox lug | backbox saver
by admin 1,581 Views -
How to remove small stripped screws | stripped laptop screws | stripped phone screw removal
by admin 1,681 Views -
How to cut aluminium
by admin 1,550 Views -
by admin 38.2k Views -
by admin 30.3k Views -
by admin 6,462 Views -
by admin 8,184 Views -
by admin 5,476 Views -
by admin 9,350 Views -
by admin 5,090 Views -
by admin 5,936 Views
