French door’s normally rely on two keyed alike euro cylinders to lock them. Replacing one of the cylinders is easy, but the other one is a bit more difficult as you have to remove the keeper plate and often drill a hole through the internal PVC profile to be able to access the euro cylinder retaining screw.
- General DIY videos Lock repair videos
- french door, french door lock
How to fit UPVC door handles that don’t quite fit
by admin 172 Views -
How to replace a multipoint lock
by admin 2,951 Views -
How to fix a broken key in a Euro cylinder lock
by admin 2,291 Views -
How to replace the batteries in a UPS | replace batteries in uninterruptible power supply
by admin 805 Views -
How to Under cut door frames
by admin 3,380 Views -
Shed door securing bar
by admin 3,478 Views -
How to fit a door viewer | spy hole
by admin 2,965 Views -
How to fit internal door handles
by admin 3,362 Views -
How to fit a bathroom door lock
by admin 3,671 Views -
Euro cylinder lock snapping
by admin 4,467 Views -
by admin 37k Views -
by admin 29.6k Views -
by admin 19.2k Views -
by admin 6,364 Views -
by admin 10.6k Views -
by admin 8,101 Views -
by admin 9,160 Views -
by admin 5,021 Views -
by admin 5,867 Views -
by admin 5,246 Views
