How to replace a single hole lever tap
This video shows how to replace a common lever basin tap. These are often called single hole taps as they are installed into a single hole where as many other taps require two fixing holes. This is normally a very simple job and can easily be accomplished by people with some previous plumbing experience.
Plumbing Videos Tap videos
lever tap, single hole tap, basin tap, lever faucet, tap fitting, tap replacement
