Radiator valves can be the cause of leaks in some central heating systems, if you find your valves have been leaking it is essential that they are tightened using a suitable spanner and also a pair of water pump pliers in order to support the valve and prevent the connecting pipes from being kinked.
Radiator valves can be the cause of leaks in some central heating systems, if you find your valves have been leaking it is essential that they are tig...
