People often damage the cutting edge of their bolt cutters the first time they use them, this is because most people cut through the shackle of the padlock which immediately dulls the cutter blades as the shackle is made from hardened steel.
- General DIY videos
- bolt cutters, bolt croppers, cut padlock
KNIPEX CoBolt Compact Bolt Cutters
by admin 6,705 Views -
Glass cutting using a glass cutter
by admin 1,993 Views -
Drilling glass | spear point glass drill
by admin 2,596 Views -
by admin 8,124 Views -
The easiest broken bolt removal ever
by admin 1,229 Views -
Removing a broken bolt using a welder
by admin 2,964 Views -
How to install deck posts | Decking posts
by admin 2,567 Views -
How to cut a bolt without damaging the threads
by admin 6,868 Views -
by admin 2,310 Views -
Garden burner bins
by admin 2,577 Views -
by admin 37.6k Views -
by admin 29.8k Views -
by admin 19.3k Views -
by admin 6,402 Views -
by admin 10.6k Views -
by admin 8,121 Views -
by admin 9,222 Views -
by admin 5,036 Views -
by admin 5,883 Views -
by admin 5,311 Views
