Hinge drills or hinge siting drills are a very useful drill for ensuring that the screw pilot hole is drilled in the dead centre of the hinge fixing hole. Please ensure that you do not buy a cheap set of these as they will not work as well as a decent quality make. Brought to you by http://www.ultimatehandyman.co.uk/
- Drilling videos Tool videos Woodworking videos
- hinge drills
External Chamfer Tool | Drill bit to remove burrs from bolts
by admin 1,466 Views -
Strap wrench – a must have tool!
by admin 2,057 Views -
Impact reamer | enlarge holes in steel easily
by admin 1,036 Views -
Blacksmiths drills
by admin 2,505 Views -
SDS drills explained
by admin 2,598 Views -
Round bar centre finder | drill the centre of round bar
by admin 1,696 Views -
Self-aligning tap wrench | self-aligning reamer
by admin 1,375 Views -
How to use an angle grinder
by admin 1,852 Views -
The easiest way to drill large holes in thick metal | Impacta step cutter
by admin 3,710 Views -
Bahco mini socket set | Bahco 2058/s26
by admin 1,377 Views -
by admin 38.4k Views -
by admin 30.4k Views -
by admin 6,471 Views -
by admin 8,202 Views -
by admin 5,505 Views -
by admin 9,370 Views -
by admin 5,097 Views -
by admin 5,947 Views
