Lenox Metal Max | diamond blade for cutting metal
The Lenox Metal Max is a diamond disc that has been made for cutting metal. These diamond blades are made from steel, with diamonds impregnated into the cutting edge. The diamond discs are safer, because they will not shatter, like abrasive discs can. Unfortunately, these discs cut much slower than a 1mm thick abrasive disc, but still have some advantages.
Lenox MetalMax
