It's often useful to know how much force is required to move an object; this can easily be accomplished using a spring balance. Once you know the value in KG’s of the item you are trying to move you can easily convert it to Newtons.
- General DIY videos
- pull force, spring balance
How to cut plastic skirting board | Cut UPVC skirting board
by admin 2,027 Views -
Fillet pointing | mortar fillet pointing
by admin 2,145 Views -
How to fix a loose wood screw
by admin 3,070 Views -
How to fix a tv to a hollow wall | Nightmare job!
by admin 1,276 Views -
How to hang a TV on a solid wall | fix Tv to wall
by admin 1,374 Views -
How to dig post holes | post hole digger
by admin 1,040 Views -
How to upgrade magnetic catches on bifold doors
by admin 2,011 Views -
Outside tap cover | prevent pipes from freezing
by admin 2,109 Views -
How to cut small parts with a mitre saw
by admin 1,132 Views -
How to use Spring toggles
by admin 2,988 Views -
by admin 36.8k Views -
by admin 29.5k Views -
by admin 19.2k Views -
by admin 6,332 Views -
by admin 10.6k Views -
by admin 8,072 Views -
by admin 9,128 Views -
by admin 4,995 Views -
by admin 5,856 Views -
by admin 5,197 Views
