Mirka Deros review
The Mirka Deros is much better at sanding than traditional sanding machines. This machine is much quitter and easier to use than most other orbital sanders. The Mirka Deros can also be used with either the 125mm pad or the 150mm backing pad making this machine very versatile. Because the machine uses Abranet abrasive pads instead of sand paper the abrasive does not get clogged up!
Painting videos Tool Review videos
mirka deros, mirka deros review, mirka ceros, mirka, abranet abrasive
