Nilfisk patio cleaner
The Nilfisk patio cleaner is the ideal solution for cleaning large areas such as decks, patio’s, driveways or walls. The brush seal prevents the water from being directed where you do not want it and the rotating head makes light work of cleaning large areas. The pressure can be adjusted by means of a dial on the top of the cleaner. If you have a large area to clean the Nilfisk patio cleaner is the ideal solution as it will connect to the lance on the Nilfisk pressure washer and make light work of any cleaning.
Link to product on eBay - https://fave.co/2J5D2lB
