Push-Loc by Melimatic is a range of push on brass fittings for use on MDPE pipe. These fittings are good quality and are easy to use, with the added advantage that they are much smaller than traditional push-fit fittings. These fittings also do not require a pipe insert, unlike compression or traditional push-fit fittings.
- Plumbing Videos
- puch-loc, mdpe fittings, join mdpe
Cutting plastic pushfit pipe | John guest pipe
by admin 5,014 Views -
How to use PTFE tape
by admin 4,021 Views -
Solder ring fittings | Yorkshire fittings | capillary fittings
by admin 1,752 Views -
How to use compression fittings
by admin 4,741 Views -
How to use push fit pipe | JG speedfit
by admin 6,198 Views -
How to fix a leaking tap connector | Push fit tap connector
by admin 1,874 Views -
How to connect flexi tails
by admin 4,877 Views -
copper pushfit fittings | cuprofit
by admin 21.7k Views -
How to cut and join MDPE pipe
by admin 21.6k Views -
by admin 39.1k Views -
by admin 30.9k Views -
by admin 19.5k Views -
by admin 6,536 Views -
by admin 10.8k Views -
by admin 8,255 Views -
by admin 8,382 Views -
by admin 5,633 Views -
by admin 9,489 Views -
by admin 5,178 Views
