Rage 3s mitre saw cutting masonry
Rage diamond blades are available here- http://fave.co/1Lc2yST
In this video I use the Rage 3S sliding mitre was and a Rage diamond blade to cut some common items made from masonry. Being able to cut masonry on a mitre saw has some clear advantages in that you can remove some of the dust by using a dust extraction unit or vacuum, you can also get some really neat cuts including mitre cuts and bevel cuts. Rage diamond blades are available for most of their mitre saws, which makes their fantastic metal and wood cutting saws even more versatile!
Diamond cutting mitre saw, masonry mitre saw, Rage 3 cutting masonry
