Removing a broken or sheared bolt or stud is never easy, but if you have a welder (a mig welder is preferred) you can sometimes weld a nut to the end of the broken bolt. The heat generated by the welding process often helps to loosen the bolt and makes removal of the bolt can be achieved very easily with a spanner.
- Metalworking videos
- remove broken bolt using welder
Removing sticky labels
by admin 3,001 Views -
How to cut a bolt without damaging the threads
by admin 6,938 Views -
Removing a wall plug
by admin 3,161 Views -
by admin 2,397 Views -
KNIPEX CoBolt Compact Bolt Cutters
by admin 6,726 Views -
How to use bolt cutters | How to use bolt croppers
by admin 2,208 Views -
How to drill out a broken tap | drill out a broken screw extractor
by admin 2,144 Views -
Removing plaster with a SDS drill
by admin 8,319 Views -
by admin 8,198 Views -
The easiest broken bolt removal ever
by admin 1,260 Views -
by admin 38.2k Views -
by admin 30.3k Views -
by admin 6,462 Views -
by admin 8,184 Views -
by admin 5,476 Views -
by admin 9,350 Views -
by admin 5,090 Views -
by admin 5,936 Views
