This video shows how to easily remove a wall plug that is no longer required and also how to fill the hole in an external wall to prevent frost damage
- General DIY videos
- remove wall plug
Removing silicone sealant
by admin 6,475 Views -
Install kitchen wall units when pipes or cables are in the way | Fit wall units stud partition wall
by admin 23 Views -
How to convert a European plug to a UK plug | two pin plug to three pin plug
by admin 4,597 Views -
Removing plaster with a SDS drill
by admin 8,315 Views -
How to remove a snapped screw from a wall plug
by admin 1,829 Views -
by admin 6,459 Views -
Wiring a three pin plug
by admin 2,788 Views -
by admin 5,936 Views -
Removing sticky labels
by admin 3,001 Views -
Removing a broken bolt using a welder
by admin 2,978 Views -
by admin 38.2k Views -
by admin 30.3k Views -
by admin 8,184 Views -
by admin 5,474 Views -
by admin 9,349 Views -
by admin 5,087 Views -
